website not working
Error 522 Ray ID: 467879d20db96fcc • 2018-10-10 10:42:11 UTC
Connection timed out
url:- https://geekcarders.ga/
If you’re the owner of this website:
Contact your hosting provider letting them know your web server is not completing requests. An Error 522 means that the request was able to connect to your web server, but that the request didn’t finish. The most likely cause is that something on your server is hogging resources.
what is the problem is going on? and how can i fixed it?
To begin with, try to disable CloudFlare and try again to visi your site.
How have you used CF? Did you tranfer your website to them or from the Cpanel?
The issue could be due to your server still being migrated: https://profreehost.com/forum/discussion/824/free-hosting-maintainance
yes but now its showing web server down? Error 521 Ray ID: 467925f6e869c32e • 2018-10-10 12:39:11 UTC
Web server is down
i thing the problem is from server its showing error everytime
@hax404inj3t404
Your website works fine. Submit Registration button however does not wor, you may want to fix it.
> @ChrisPAR said:
@hax404inj3t404
didnt get you bro where i need to registration?
@hax404inj3t404
You need to wait for DNS to fully propagate. So you can use the xenforo script as intended.
https://intodns.com/geekcarders.ga
http://badtech.ezyro.com/
http://badtech.gq/
@hax404inj3t404 switched to using MyBB, however the site looks so wrong from here.
Maybe you could try re-installing it through Softaculous, or use another software such as LayerBB, phpBB, or Vanilla (my favorite for forums :smile:)
@ChrisPAR
Xenforo is closed source not in script installer. He has the xenforo script all he needed to do was wait till dns fully propagated, fix the Apache handlers (5) and install. He could have installed then fixed the errors. Some may not have been able to work around.
That is the idea of community help forum. Post the errors. Xenforo has most common servers errors how to’s.
He does not use XenForo anymore! Visit his site, it says Powered by MyBB!
> badbot said:
I do not need to visit the site.
see the @ badbot that sends me a notification, remove the at sign and I will not be notified of your quote to OP
Okay, if you think that is better. Sorry.
i switch forum to mybb and its good :stuck_out_tongue:
Okay, I am happy that this worked.
I don’t know if you care but your site shows like this to me:
