after struggling with my .it domain, I decided to buy a .com domain from godaddy. I added the NS as suggested in the support section of the website, and everything works perfectly.
Now, since I need also the .it domain (can’ transfer to a different registrat), I decided to point it to the .com domain. At the moment I’m setting the CNAME to the .com domain, but once I visit the .it domain, it returns http://suspendeddomain.org/ instead of the actual website.
Is it normal? Is there any better solution to correctly point it?
Thanks
Well, it is not normal. Your .com domain is working fine but for .it you are probably using the A record with wrong IP address.
