I just noticed that I had installed a private key on my server while it’s completely unneccesary, because all of the SSL stuff is being handled by CloudFlare. I can’t seem to remove/uninstall it though. Whenever I clear the textbox, and hit upload, I get an error message saying that it can’t be empty.
Any help?
EDIT: This also leads to my website giving a 404 error. You can check it for yourself here: https://www.webdesyners.gq/
Any help?
The Private Key does not mattter. As long as you have CloudFlare and have not selected the Full Strict Option on SSL Section it will be ignored.
Also, I don’t think this is the reason you get a 404. Are you sure that there is an index.html/index.php file in your htdocs folder?
Yes, there is an index.html file in the htdocs folder. I check that already. Also, on my other website I have been using the Full Strict option on CloudFlare, but I have not set the Private Key. It works fine there.
Ok, well I just reconnected with CloudFlare and it doesn’t give me the error anymore. The IP Adress was right already, so that wasn’t an issue. I’ll wait for a few hours to check if SSL starts working. Thanks for the help!
