SSL error
Hello, I have an SSL cert ready for use signed by a CA using the CSR cpanel gave me, but it says that The certificate uploaded is NOT for the domain name even though it is from the CA. What should I do?
Did you manage to solve it? Same issue with me
same problem with me please help me!
Hello
Kind of explains itself. This is a free service and has domain name that does not match the cert. Email support and ask if it can be used on the free services.
It can be used on free accounts only if you have added your own TLD. However, it cannot be used on our free sub domains.
Ok tanks now i got it !
