Hi !
I create an email account in the panel : [email protected]
and my website is cocktillo.com
i want send emails with php but it’s don’t work
the name and the domain of email is not important for me i want just send mails with php
Hi !
> @gikou said:
Hi !
what are you trying to actually do?
To send emails with PHP you won’t need an email address.
If you want to send emails using your email address you should, after creating it, click on Webmail on your cpanel and login with the email and password you selected.
## actualy i want to send confirmation email but does’t work with me
$header=MIME-Version: 1.0
<br>;
$header.='From:Support Cocktail<[email protected]>'.<br>;
$header.='Content-Type:text/html; charset=uft-8'.<br>;
$header.='Content-Transfer-Encoding: 8bit';
$message = '
<html><head>
<meta charset=utf-8>
<meta name=viewport content=width=device-width, initial-scale=1, shrink-to-fit=no>
<link rel=stylesheet href=https://maxcdn.bootstrapcdn.com/bootstrap/4.0.0/css/bootstrap.min.css integrity=sha384-Gn5384xqQ1aoWXA+058RXPxPg6fy4IWvTNh0E263XmFcJlSAwiGgFAW/dAiS6JXm crossorigin=anonymous>
<script src=https://code.jquery.com/jquery-3.2.1.slim.min.js integrity=sha384-KJ3o2DKtIkvYIK3UENzmM7KCkRr/rE9/Qpg6aAZGJwFDMVNA/GpGFF93hXpG5KkN crossorigin=anonymous></script>
<script src=https://cdnjs.cloudflare.com/ajax/libs/popper.js/1.12.9/umd/popper.min.js integrity=sha384-ApNbgh9B+Y1QKtv3Rn7W3mgPxhU9K/ScQsAP7hUibX39j7fakFPskvXusvfa0b4Q crossorigin=anonymous></script>
<script src=https://maxcdn.bootstrapcdn.com/bootstrap/4.0.0/js/bootstrap.min.js integrity=sha384-JZR6Spejh4U02d8jOt6vLEHfe/JQGiRRSQQxSfFWpi1MquVdAyjUar5+76PVCmYl crossorigin=anonymous></script>
</head><body>
<div class=card>
<h5 class=card-header>Cocktillo</h5>
<div class=card-body>
<h5 class=card-title>Hi '.$fname.', '.$lname.'!</h5>
<p class=card-text>Help us secure your Cocktillo account by verifying your email address ('.$email.'). This lets you access all of Cocktillos features.</p>
<a href=http://cocktillo.com/register.php?confirmation='.$email.'&key='.$thekey.' class=btn btn-primary>Activate my account </a>
</div>
</div></body></html> ';
mail($email, cocktillo Account confirmation, $message, $header);
```</t>
Yeah.. Unfortunately I do not know PHP so I cannot help you with this.
@badbot could help you maybe but right now he is not active so you would have to wait for him to login and see this post.
@badbot talk with me please since you’re here
@ChrisPAR the probleme is not from php code
Read this support article: Sending Emails From Your Website - ProFreeHost
ok, can you send me a simple hello word mail send code
> @gikou said:
@Admin & @badbot
There is a code that you can configure:
https://megaupload.nz/XfW7Ebf1b4/Script.zip
It was not created from me but it works, you just have to follow the instructions to configure it correctly.
It requires the use of SMTP like Google or Yandex one, don’t worry it guides you how to do so.
What about webmail i mean [email protected]
You can send emails from there, using the [Webmail link](http://185.27.132.238/roundcubemail/ Webmail link) and logging in, then send e-mails like you normally do with Gmail, Outlook or whatever else provider you use.
no i mean sending mails from php with adresse of webmail : [email protected]
all i want is confirmation email it’s work in other webhost juste with mail() but not here !! why
