Second level subdomains
I want to create a sub2.sub1.domain.com. But then cPanel says this Illegal characters in the naming field, please verify input. .3. How can I add second level subdomains?
Here is a example:
@TheCrafters hot linking is not supported. That’s why the images you share from your web account do not appear.
ok, thanks for the info
Hay
In the create new sub domain feature there is to fields. The write in, and drop down. The drop down you select the domain and or the sub domain. Then you fill in the field with desired sub domain. No dot!
I understand but I can just use my domain from the drop down menu. I can not use a sub domain. Do you know any work around?
> @TheCrafters said:
Here is a example:
What did you send
> @Jokopolo said:
What did you send
I just re-uploaded the image that @TheCrafters posted.
Now I’m not understanding what you want.
top level domain = unaux.com
sub domain = badbot.unaux.com (also knows as a free domain) which is at the bottom of the drop down menu.
write in field = broken
drop down = badbot.unaux.com
you will get: sub domain = broken.badbot.unaux.com
You have to create the sub.domain and then create the sub.sub.domain.
Write the domain name your trying to achieve and it will be easier to tell you how to create.
I added my domain as a parked domain. I made a subdomain called wiki.domain.com.
But now, I want to create en.wiki.domain.com. You told me to choose wiki.domain.com from the dropdown but that’s the problem, it is not there. I could successfully create a sub.sub.domain.com with the free domains that were offered in the dropdown, but it doesn’t work with my very own domain. Thank you.
YES I FIXED IT. I need to add wiki.domain.com as a addon domain and then add ‘en’ as a subdomain. Thank you all for your kindness
