Redirect not working
Dear sir,
I have created website www.bigvirtualmart.com
i want to redirect it to www.bigvirtualmart.com/wings/
From C panel I tried many times to redirect , but after setting the redirect not working.
Kindly Replay me.
Thanks
Rajesh
>Dear sir,
Kindly Replay me.
Thanks
Rajesh
Your .htaccess file is in conflict. Either remove the .htaccess and set the redirect from cpanle or correct your .htaccess
Your main .htaccess should look something like thise:
RewriteEngine On
RewriteRule ^$ /wings [L]
````</t>
Dear sir, Can you describe details please?
Please help, If needed i Can provide you the Admin details.
Thanks.
Rajesh
Thanks.
Rajesh
I see that you changed your htaccess already and it is redirecting to /wings now.
I hope the issue is solved.
Dear sir, The settings from cpanel and htacess also not working , hot to solve.?
ItÂ’s not working Kindly Solve it for me, on cpanel settings the settings saves successfully, and redirect to blank page.
Thanks
Rajesh
The Domain working Successfully, Thanks for Your Support.
Rajesh
