Not receiving e-mails.
Hello all.
I’m having quite a bit of an issue here: even after setting the MX record, I am still unable to receive e-mails, however, I am able to send them.
I have also tried changing the MX record to mx.byetcluster.com, but to no avail. I am using CloudFlare, and I am also using a custom domain (donau-os.com).
Thank-you.
@badbot
Okay, I disabled Cloud Flare and then I added my website manually through their website. I removed the MX record from my website and re-added it via Cloud Flare, but I am still not getting messages.
Hello!
It seems that I have received some older emails, although I am yet to receive some I sent today as a test.
I did this in cloudflare:
Also, I have noticed recently that my subdomains are not working.
It seems that I’ve received some e-mails I sent earlier again.
I changed the MX record to point to 185.27.132.238.
I tried again, I think it actually just takes a bit of time before I get the e-mails, like a day or so. I’ll keep you up to date.
By subdomains I literally mean the subdomains. I had a subdomain for bugtracking, tracker.donau-os.com, and when I go to it now it simply fails (this site’s IP address cannot be found). Tried making another subdomain, same issue.
I fixed the subdomain issue above by adding an A record in CloudFlare and guessing the last number of the IP lol
Nevermind, getting a 404 now.
I’ve got the mail working! Stupid me set the MX record name to donau-os.com instead of mx. Thank you so much :slight_smile:
However, I’m still having that issue with the subdomains.. :frowning:
E-Mail stopped working again. Oh boy :frowning:
I have the following for mail in my DNS settings at the moment:
TYPE NAME ADDRESS
A mx 185.27.132.238
MX mx 185.27.132.238
Hello!
Thanks for helping me :slight_smile:
I did that, but both of them seem to be having the same issue still :frowning:
@Disreality for your subdomain problem, can you try making your subdomain point to the main domain displayed in cPanel via CNAME?
Example of main domain:
@ChrisPAR @badbot
That seems to have fixed the subdomain issue! It seems to load just fine now. Thank you so much!
E-Mail also seems to be working fine, too. I left the fix as it was last night, and this morning it seems good.
Thank-You so much! You’re the best.
