Hello,
Your name servers are not working.
Mismatched NS records WARNING: One or more of your nameservers did not return any of your NS records.
Error DNS servers responded ERROR: One or more of your nameservers did not respond:
The ones that did not respond are:
198.251.86.152 198.251.86.153
Pass Name of nameservers are valid OK. The nameservers reported by the parent send out nothing as shown above. I can’t check nothing so it’s a green!
Error Multiple Nameservers ERROR: Looks like you have less than 2 nameservers. According to RFC2182 section 5 you must have at least 3 nameservers, and no more than 7. Having 2 nameservers is also ok by me.
Pass Nameservers are lame OK. All the nameservers listed at the parent servers answer authoritatively for your domain.
Pass Missing nameservers reported by parent OK. All NS records are the same at the parent and at your nameservers.
Error Missing nameservers reported by your nameservers You should already know that your NS records at your nameservers are missing, so here it is again:
Please Help
