Hello my sub domains are not working, like shop.thepeopleschoicestore.com Please help me rectify this. thanks
You have to add the A Record to CloudFlare
Okay, so how do i do that please. Can you kindly tell me the steps as i am not that techy
Thanks
Thanks
The first step is to login to cloudflare.
Then when you are logged in, you click your domain. I will use mine for example.
Then you click DNS, it should look like this:
When you are there, scroll down until you see this bar:
add the following details:
Then hit add record.
You should wait up to 24 hours for the domain to update it’s DNS
after that, it should be good. (so far, every time I have done it, it has done it instantly.)
