You probably changed your homepage from wordpress dashboard. If so, you need to edit database manually and change it back. Steps are similar to followings:
Access phpMyAdmin from control panel and connect to database
Open “wpxx**_options**” table. wpxx is example it can be different in your case but “_options” will be same.
