I can not send or receive emails.
I can not send or receive emails. It was working fine until yesterday. Mx record is ok, and i don’t changed then a few weeks ago.
[Print1 mx cf](https://ibb.co/nBMpSFr Print1 mx cf)
[Print mx pf](https://ibb.co/J3jBSgq Print mx pf)
Domain: [jonathan-ventura.com](https://jonathan-ventura.com/ jonathan-ventura.com)
Cloudflare breaks incoming and outgoing emails. There is no workaround for this at the moment.
Cloudflare only breaks the email if you activate in Cpanel, if you activate directly in cloudflare the email works fine. well, it was working until yesterday.
Has there been any change today in the profreehost system?
@jventura
your using mx.unaux.com 185.27.132.238 185.27.134.254 (no glue) Sometimes it will stall send/receive. For spam/phishing checks. You may get some back after a while.
I temporarily resolved this using the email service of yandex.ru. until I can access normally the roundcube…
> @jventura said:
@badbot said:
@jventura
Can you say more about this?
Because i am also having this problem.
Thankyou
Unaux.com seems to be having problems.. again. Until then, use mx.ezyro.com or for even bigger safety, use mx.byetcluster.com
> @tradybees said:
@jventura said:
@badbot said:
@jventura
Thankyou
I changed the MX records and add ns servers to yandex.ru in the cloudflare, You can see in prints bellow, but the site still hosted in Profreehost.
access [https://connect.yandex.com/portal/admin](https://connect.yandex.com/portal/admin https://connect.yandex.com/portal/admin) and create a accont, and configure the dns settings in cloudflare.
i created 2 emails in yandex, [admin@jonathan-ventura.com](admin@jonathan-ventura.com admin@jonathan-ventura.com) and [contato@jonathan-ventura.com](contato@jonathan-ventura.com contato@jonathan-ventura.com) they is working fine.
Unaux did not work again.
Yandex emails are cryptographed and not be down, Unaux not.
(OBS: i not sure if yandex works with freenom domains, like .ml .ga .cf etc. i used a .com domain buyed in godaddy.)
[Cloudflare ](https://dash.cloudflare.com/ Cloudflare )print 1 :[https://ibb.co/6ZXr1Nb](https://ibb.co/6ZXr1Nb https://ibb.co/6ZXr1Nb)
[Cloudflare ](https://dash.cloudflare.com/ Cloudflare )print 2: [https://ibb.co/sKvK9wd](https://ibb.co/sKvK9wd https://ibb.co/sKvK9wd)[
Yandex admin tools](https://connect.yandex.com/portal/admin
Yandex admin tools) print: https://ibb.co/GV0PJzn
[mail Yandex](mail.Yandex.com mail Yandex) print: https://ibb.co/wSYHhbq
You can also use Zoho Mail if you want, but keep in mind that Zoho supports free domains only if you contact their support and ask them to whitelist the domain for you.
Zoho needs a cellphone confirmation and you only can make 1 email account with only 1 domain
