Can you share a screenshot of what issue you are facing with permission?
Are you redirecting from your unaux/liveblog365 subdomain to original website?
You need to go to VistaPanel from Client Area, then open Redirects and then click on Alter Redirects after choosing your subdomain. From there on you will be able to add your original domain as redirection.
I already did that and i add the subdomin and after that the new domin and this messege appears
( Forbidden
You don’t have permission to access /panel/indexpl.php on this server.)
,so ı want to know what i have to do to solve this the website is not appear at all and I tried 2 ways from VISTAPANEL and FILE MANAGER I don't know what to do ,can suppport solve this for me it took too mush time to add this new domin and I cannot work without the website
It seems like the reason the old domain is still appearing is that your settings are still locked in the database. You can override this immediately by editing your wp-config.php file again.
Log into your Online File Manager, open the htdocs folder for your new domain, and edit the wp-config.php file. Find the line that says /* Add any custom values between this line and the "stop editing" line. */ and paste the following code right below it:
PHP
define( 'WP_HOME', 'http://your-new-domain.com' );
define( 'WP_SITEURL', 'http://your-new-domain.com' );
If you can then log in to your dashboard, remember to go to Settings > General to verify the change.
It seems you are not logged in to the client area.
how can ı ad SSL to the website
Kindly refer to SSL-HTTPS section on ProFreeHost Forum:
