webslexa
(Webslexa)
1
Hello,
My subdomain is:
direnis-stuttgart.unaux.com
HTTP works normally:
http://direnis-stuttgart.unaux.com
However, HTTPS does not work:
https://direnis-stuttgart.unaux.com
The browser shows:
ERR_CONNECTION_RESET
I also tested the server from Windows PowerShell:
curl.exe -Iv https://direnis-stuttgart.unaux.com
The connection reaches:
185.27.134.144:443
but the TLS handshake fails with:
Recv failure: Connection was reset
SSL/TLS connection failed
I also tested port 443:
Test-NetConnection 185.27.134.144 -Port 443
Result:
TcpTestSucceeded : False
The cPanel SSL page says that subdomains have SSL automatically enabled.
Could you please check whether HTTPS/SSL is correctly enabled for my subdomain on the server?
Thank you.
Frost
(Moderator)
2
Thank you for the thread. I have escalated the issue to system admin. Hopefully it will be resolved soon.
Hello,
My website was working correctly, but it is now completely inaccessible:
https://100giga.unaux.com/
The hosting account is active and the files are still in htdocs.
I have not deleted or moved the website files.
The website currently does not load, and HTTPS also does not work correctly.
Could you please check the server/vhost configuration for my account?
Domain: 100giga.unaux.com
Username: ezyro_42730552
Thank you.
Frost
(Moderator)
4
Your website is currently live and working.
