Hello, I currently have a website at https://tlvmmod.unaux.com/, but it reports that it is not working when accessed via HTTPS. Could you please explain why this is happening or help resolve the issue?
Hi @ht2465444, welcome to the community.
HTTPS is working correctly on your site. The warning you’re seeing is from Google Safe Browsing, which means Google has flagged the domain as unsafe. This isn’t related to SSL and isn’t something we can remove on our end.
To get the warning removed, add your domain to Google Search Console, check the Security Issues section to see what was flagged, fix it, and then request a review. Reviews usually take a few days.
Also, your site is currently showing a 403 error because there’s no index.html or index.php file in your htdocs folder. Uploading your site files there will fix that.
