How do i add .tk
when i try to add .tk its not getting added help pls it shows unavialable but for other it showing avaiblabel
You cannot add .TK domains to ProFreeHost.
Hi,
as @TheCrafters mentioned you cannot use .tk domains. This was implemented because of many spamming/abuse sites using this free domain extension.
Please consider using another free domain such as .ga or .cf
Since you obviously have access to freenom, try using .ga, .gq or .cf as they are work atm. (As @ChrisPAR said) I’ve tested with this and it works!
