Help Please?
My account has been suspended, because This abuse has been suspended because our abuse system has detected some kind of phishing activity.
I think, it’s wrong to have a problem caused by me.
I have published it with the site builder you have submitted.
I’ve been waiting a long time. I’m checking in, waiting for an answer and help.
I read the first topic.
I sent mail to [email protected]
@Cafer
You need to handle this yourself. Post your domain!
Suspension
Wait it out!
HowTo delete your domain
https://cpanel.ezyro.com/ → Domains → Addon Domains → Delete domain.
https://www.badtech.gq/
The problem is, I don’t know the cpanel information. I’ve done all the transactions from profreehost.com and now
I can not enter the site(cpanel).
What can you recommend?
@badbot
l Login to Profreehost not a problem
Manage Builders
Create/Manage drag & drop builders for this account
Unavailable
I used the site with my domain (here) ezyro.com do not know
I’ve tried to use another host but I get the The selected domain is already in use on unaux.com. Please remove the domain from your account at unaux.com before you can host it on ***** error
Now it seems like there is nothing I can do other than waiting for my account to be deleted
Thanks for your interest
Account mail [email protected]
> @Cafer said:
@badbot
Manage Builders
Unavailable
Login to your account, then login to control panel, go to the Add-on Domains section and press delete next to your domain.
