Hello, I need help
I know i am signed in as admin but i am not supposed to me!
I am logged in here for NO reason, and this happened after activating my account! and i cannot log off Help ME :S !
My username is: TheCrafters
>Hello, I need help
We are using a third party forum software, codoforum, it needed patch. It has happened before to the other users. We are planning to move to a better forum software but this needs extensive planning and time.
Thank you for reporting the issue.
>>Hello, I need help
Hello, I think you should try out Either ElkArte or SMF, i have only tested SMF, that one works just fine, but i think ElkArte works just the same way (wasntme)!
My Username is: TheCrafters
>>Hello, I need help
The Issue is fixed Thanks ![]()
