Hello, I created an account but I can’t log in via FTP or through your file manager. Both keep telling me the password is incorrect. I’m using the one you gave me.
Please help. Thank you.
What error do you get when you click File Manager from Client Area? Did you refer to this article on setting up FTP?
Understood.
Are you able to log in to Control Panel? And also when did you make your account? Was it active recently?
| Status: | Active |
| Created On: | 2026-03-18 08:15:19 |
| Obviously, I’m logged into my profreehost.com account. |
Alright we are taking a look at your account and will update you soon.
THANKS YOU MY BRODER
Check now. You should be able to login.
