When I try to FTP into my website from Filezilla, it does not work.
I’m using the following details,
host: ftp.unaux.com
username: unaux_*****
password: PFH password
port: 21
I’ve tried this from different devices, different operating systems, different internet connections, etc. It still doesn’t work.
Is it broken, or am I doing something wrong?
host: ftp.unaux.com
port: 21
Try replacing ftp.unaux.com with ftpupload.net . It should work. Also double check your password.
host: ftp.unaux.com
port: 21
Is it broken, or am I doing something wrong?Try replacing ftp.unaux.com with ftpupload.net . It should work. Also double check your password.
I will try ftpupload.net . My password is correct. Thanks.
Nope. ftpupload.net doesn’t work either.
Filezilla just connected and transfer was successful.
Filezilla site manager set config
Host: 185.27.134.11
Protocol: FTP
Encryption: Only use plain FTP (insecure)Login Type: Normal
User Name: site account (ezyro_********)
Password: cpanel password
login here: https://profreehost.com/account/
Manage site whatever your is!!
password → disable hide. cpanel password
Thank you!!
