Because it did not work already did solution. Please fix?
Are you still experiencing the issue? and I see that you are not using any port.
Check this support article: Unable to Connect to FTP! - ProFreeHost
Check this support article: https://profreehost.com/support/files-and-directories/unable-to-connect-to-ftp
Control panel not loading then.
You already read all well but if it did not work always.
https://cpanel.unaux.com is loading fine here. I also just logged into the FTP. You should use port 21
It says the virus is wrong. So why the detection?
FTP for can you change password again?
> @Benzitczo said:
It says the virus is wrong. So why the detection?FTP for can you change password again?
Avast does this from time to time, This is normal. The website is Fine, just avast like to mess around, in your browser causing False Positives.
It already seems several times that dangerous detection that is why xd virus.
Well, I do not use Avast internet security, but I do use Avast antivirus.
So I cannot help you. Maybe there is a way to Exclude it from your Online security checks.
Have you tried adding exceptions for each domain?
If you open up the program, go to General and click on urls and put all the domains in there and press OK then it should not popup on websites listed on the url list.
