I would like to use your hosting service to store small files, I have a PHP script that is used as a file manager, I would like to know if I can use it here to store my files using one of the servers that you make available, as your php system only allows uploading 10 megs, all the files that I will upload are small below 10 megs.
As long as you do not upload any prohibited content, it’s alright.
Also, there is a file manager already. Most of the 3rd party file managers are not compatible.
