Directory listing
When I search my site in the nav bar, after, I see the directory listing.
And I want to see my WP page.
How can I solve that?
The adress is techlovers.ezyro.com
move the files on wp to outside of the wp
or create index file outside the wp that command the page direct to the index inside the wp folder
When I redirect the adress to techlovers.ezyro.com/wp. It doesn’t work.
Chrome says ERR_TOO_MANY_REDIRECTS
So I need to delete it and reinstall into htdocs
That’d be the easy way. If you have data that you don’t want to lose, you can always search on google for ways to move wordpress. e.g: [Moving your WordPress to a different folder ](Moving your WordPress to a different folder | Web Hosting Hub Moving your WordPress to a different folder | Web Hosting Hub)
