hi everyone, Im has uploaded web using codeigniter.
I have problem with connnecting database mysql.
Error like this:
Unable to connect to your database server using the provided settings.
Filename: core/Loader.php
Line Number: 346</t>
Error like this:
and my setting database is:
$db['default']['hostname'] = 'sql204.unaux.com';
$db['default']['username'] = 'unaux_aaaaaaaa';
$db['default']['password'] = 'aaaaaaaa';
$db['default']['database'] = 'unaux_aaaaaaaa_baidu';
$db['default']['dbdriver'] = 'mysql';
$db['default']['dbprefix'] = '';
$db['default']['pconnect'] = TRUE;
$db['default']['db_debug'] = TRUE;
$db['default']['cache_on'] = FALSE;
$db['default']['cachedir'] = '';
$db['default']['char_set'] = 'utf8';
$db['default']['dbcollat'] = 'utf8_general_ci';
$db['default']['swap_pre'] = '';
$db['default']['autoinit'] = TRU</t>
I’ve never used codeigniter, but at the last line shouldn’t it be TRUE instead of TRU?
Furthermore, you can refer to Line 346 to find which setting is causing the issue. Double check your database and password.
My Database is not connecting please help, see picture https://ibb.co/kVCRRo
First of all you just shared your password online, which is very dangerous.
And secondly, can you try removing the special characters?
thanks i was aware of that i was willing to change every bit of information there in picture, now its working, thanks Chris…
You are welcome.
I am glad I was able to help!
