Hi! I was trying to set up 2 crons to run at 00:00 everyday, from cron-job.org, as I saw here
But it seems it doesn’t work - as I tested, they receive: redirect + “This site requires Javascript to work, please enable Javascript in your browser or use a browser with Javascript support”
(Because of the anti-bot/anti-abuse practices I believe)
If cron-job.org isn’t working, its requests are being blocked by the same security system, and this can’t be whitelisted on free accounts.
As an alternative, you can trigger the task on visitor traffic e.g. save the last run date in a file or your database, and have your site check it on each page load. The task will run on the first visit after the scheduled time, so if you need it to run at an exact time.
