Cookies are not enabled (Error)
I keep getting this error. My Cookies are enabled, I did everything according to the instructions. It still doesn’t work.
Many Forum Posts say that this issue was fixed. That’s not the case. I tried different browsers too.
Hi homer, welcome to the forum!
We just tested this on our end, and the security cookie is being set correctly, so the system itself is working. That usually means something on the browser side is blocking it. A few things to try:
  1. Turn off ad blockers and privacy extensions for the site, or test in an incognito window with all extensions disabled.
  2. Allow third party cookies, or add an exception for the site. Brave Shields, Firefox Strict mode, and Safari tracking protection often block them.
  3. Clear the cookies for your domain and reload.
  4. Disable any VPN or proxy and try again.
  5. Make sure your device’s date and time are set correctly.
If it still happens, please share a screenshot of the error and tell us exactly where you see it (your website, the client area, or the control panel login), along with the URL. That will help us narrow it down.
