Can't Enable Cloudflare
Im using a custom domain but when i try to activate cloudflare, i get this error ** CLOUDFLARE ERROR : No user_key. **
Hello,
Send an email to support with your username/email address.
Whats the email to support sorry?
Hello,
Cant find it anywhere.
>Hello
Did you get a user key from cloud flare? https://www.cloudflare.com/
The support email address is on the support forum category front page. https://profreehost.com/forum/index.php?u=/category/support-forums
It is contact at profreehost dot com. send your username or email address you signed up with.
No i didnt, how would i get it? When i get it what should i do with it?
>Hello
The cloud flare website has documentation that will help you get threw the install/activation process. It will also tell you where and how to use the key.
Here is the link to cloud flare again!!
Can you link me to this documentations please? i don’t know what to look for :S
>yep
https://support.cloudflare.com/hc/en-us
i mean to the specific document, you just linked me to the support page, i dont know what im looking for.
