About MX Records
How we can we setup the MX Record to receive emails ???
open up the MX Entry and add a record like this one: doing this allows you to use the Email client that they provide
I’m actually having the same problem i’ve tried several things, this is where they are currently though.
cmd.unaux.com mx.byetcluster.com. 0
cmd.unaux.com mx.unaux.com. 0
cpsfilehost.ml mx.byetcluster.com. 0
cpsfilehost.ml mx.unaux.com. 0
hryy6.unaux.com mx.byetcluster.com. 0
My domain name is registered through freenom (not sure if thats relevant) i can send emails just fine but when i use my gmail account to send an email to the address in question, i get this message
Your message wasn’t delivered to [email protected] because the domain cpsfilehost.ml couldn’t be found. Check for typos or unnecessary spaces and try again.
what am i doing wrong?
@Curtis Your domain’s nameservers are not pointing yet
hmm, that was the first thing i did was change those. i’ll try doing that again
@Admin , since you can see from your end, i made the changes here, did they stick?
Changes Saved Successfully!
Nameservers
You can change where your domain points to here. Please be aware changes can take up to 24 hours to propogate.
Use default nameserversUse custom nameservers (enter below)
Nameserver 1
NS1.UNAUX.COM
Nameserver 2
NS2.UNAUX.COM
@Curtis said:
NS1.UNAUX.COM
NS2.UNAUX.COM
@Curtis
Use these at least ns1 and ns2 but all 5 would be better
ns1.byet.org ns2.byet.org ns3.byet.org ns4.byet.org ns5.byet.org
i dont understand @badbot am i supposed to take these nameservers you’ve provided and input them along with what i have already?
> @Curtis said:
@badbot said:
@Curtis said:
NS1.UNAUX.COM
NS2.UNAUX.COM
@Curtis
or is what you’ve provided for my mx records?
ok so then i’m all set @badbot ? i sent a test email from gmail to [email protected] did not receive an error in gmail. but also did not receive the email on the other end.
alright, I’ll give it some time then and see if everything kicks in. thanks :slight_smile:
Read this also: Sending Emails From Your Website - ProFreeHost
