Can not open file manager 404 Not Found
and will not even over FTP client
My sub domain
igrajmose.ezyro.com
Open File Manager and then 404
P.S. I have some subdomains but the result is the same
jerrynidzo.ezyro.com
It only seems to be the online file manager (http://185.27.134.9/).
The best thing to do (if you have a FTP client) is use [ftp.ezyro.com](ftp://ftp.ezyro.com ftp.ezyro.com). You cannot edit it from your browser, but you can from a client. I recommend [FileZilla](https://filezilla-project.org/download.php?type=client FileZilla). There is a Windows [64-bit](https://filezilla-project.org/download.php?platform=win64 64-bit), and [32-bit](https://filezilla-project.org/download.php?platform=win32 32-bit) version, other versions are: [Linux](https://filezilla-project.org/download.php?platform=linux Linux) and [OSX](https://filezilla-project.org/download.php?platform=osx OSX)
igrajmose.ezyro.com is active. So if you login at: https://profreehost.com/account/ and went into Control panel. Still getting 404, we have to look at your end.
no proxy
clear browser cache
firewall virus protection, check out the stickies at top of threads. https://profreehost.com/forum/I did just log on and verified the online file manager and ftp services are functioning normally.
You may be getting near the free account limit and or past it.
I am having the same issue, it only seems to be the online file manager as i said.
otherwise, everything is fine. Remember, [profreehost is still recovering from a DDoS attack.](https://profreehost.com/forum/discussion/619/ddos-attack#latest profreehost is still recovering from a DDoS attack.)
> @TheCrafters said:
@badbot said:
igrajmose.ezyro.com is active. So if you login at: https://profreehost.com/account/ and went into Control panel. Still getting 404, we have to look at your end.no proxy
clear browser cache
Maybe he DDos does not do all that he needs
Attac
Sorry for English Google Translator
I use FILLEZILLA, but only succeed in opening the subdomain
> @Jerry said:
The best thing to do (if you have a FTP client) is use [ftp.ezyro.com](ftp://ftp.ezyro.com ftp.ezyro.com). You cannot edit it from your browser, but you can from a client. I recommend [FileZilla](https://filezilla-project.org/download.php?type=client FileZilla). There is a Windows [64-bit](https://filezilla-project.org/download.php?platform=win64 64-bit), and [32-bit](https://filezilla-project.org/download.php?platform=win32 32-bit) version, other versions are: [Linux](https://filezilla-project.org/download.php?platform=linux Linux) and [OSX](https://filezilla-project.org/download.php?platform=osx OSX)I use FILLEZILLA, but only succeed in opening the subdomain
@Jerry
What are your other domains
@badbot
It was just my cache :neutral: it now is functionally normally.
> @TheCrafters said:
jerrynidzo.ezyro.com@Jerry
What are your other domains@badbot
few post up
[ovdje](https://profreehost.com/forum/discussion/comment/1837/#Comment_1837 ovdje)
I succeeded in setting a wordpress on a subdomain
igrajmose.ezyro.com,
File manager
But you seem to have reduced the upload size.
The file size of 5 MB has been marked as large
No uploads via FilleZille are not yet possible
[Image](http://igrarazbibriga.ga/wp-content/uploads/2018/02/ftp-2.jpg Image)
I have a new problem.
Some facebook pages block us for sharing
That this does not happen because of the DDos attack.
These are domains with a problem
[Image](http://igrarazbibriga.ga/wp-content/uploads/avatar_images/facebook.jpg Image)
http://dalmacijaonlinepazar.ga
http://dalmacijaknjigashop.ga
Several ways to get around this. Dividing the wp.zip up into smaller zips is the ezy way.
filezilla setup:
use for host: ftp://185.27.134.11
port 21. If I remember I used port 25 or 26. you can try them all.authentication use plain text. I had to disable the starlite and ssl.
I also found that the operating system file manager windows explorer, connects better. If you want to try it just use ftp.ezyro.com in the location bar of manager and wait for popup login.
In my case, dolphin file manager (debian 64 bit kde plasma). It has duel pain. local file in one, and htdocs in the other. You can edit the files with text editor an save locally. The transfer to htdocs with file manager. All on the fly.
I can not open through the filezilla in any way
why disable SSl
bookface blocks us because of spam rating.
ssl is why you can’t connect filezilla. no ssl (https, ftps) for free service.
Deleted its ssl certificate from all subdomains
Facebook removed my block from [one domain](http://igrarazbibriga.ga one domain) because I sent a complaint
I also complained to other domains
But the subdomain jerrynidzo.ezyro.com is neatly opened with fillezilla
Why do not other subdomains be opened?
[Link](http://igrarazbibriga.ga/wp-content/uploads/avatar_images/fillezilla.jpg Link)
They should open with filezilla. Do you store the ftp server? Delete them and recreate. Or do you just connect on the fly.
I use all options but there is no help
But I have a wordpress plugin file manager and a database manager that helps a lot
