Dear,
Your NS not pinging at all. How can I host my website. It is unexpected.
Regards,
Sk Sabbir Ali
Dear,
Regards,
Sk Sabbir Ali
Then why my website is not pinging? Whereas I have set my NS to ns1.ezyro.com
ns2.ezyro.com. If it is not pinging then how can I access my website or FTP?
OK great. Thank you dear.. It is pinging. Solved.
Dear,
I cannot login into webmail. showing login failed with correct user name and password. What to do?
Yes the email service is restricted on free hosting. It allows only sending client confirmation emails. But webmail is working on my end. I can check yours if you send me your username to check whether that’s an IP specific issue or server side issue.
info@protechtionindia.com
Password: (removed by badbot)
>Dear,
Regards,
Sk Sabbir Ali
Dear,
if you are using .UNAUX.com
Then the .ezyro.com is .unaux.com
That is how i fixed mine
