Hello ProFreeHost Support,
My website, keyboardviet.liveblog365.com, is running XenForo 2.3.
The public website works normally, and the Admin CP login page loads correctly. However, when I submit the login form, the following request fails:
Request: POST /admin.php?login/login
Response: HTTP 403 Forbidden
Server: openresty
Content-Type: text/html
I have tried a different network, but the issue persists. The problem appeared after installing or updating an add-on or theme.
Could you please check your OpenResty access/error logs and any applicable WAF or ModSecurity rules to determine why this POST request is being blocked?
If a security rule is incorrectly blocking the request, could you advise on a safe, targeted fix? I would prefer not to disable security protections globally or modify my database.
Thank you for your help.
