Various errors to fix
Hi, I’m new on your system, I created a free site with free host, then I list a summary of the matter.
SITE LINK → http://www.aza-repacks.unaux.com
1 - SSL I was unable to configure it, as the Italian language is missing, which makes me a little difficult to better understand what to do.
1a - can SSL be configured for free? ie make the site from http to https?
1b - Other services like Altervista allows you to switch from http to https for free, here I can’t do it.
[SCREENSHOT](https://prnt.sc/rxmism SCREENSHOT) - This is the Altervista panel
2 - Wordpress installed and configured.
3 - Wordpress set for my Italian language.
4 - Set theme, Astra
5 - I have my plugins, bought and given away.
6 - How come in Account Details-> Main domain this URL appears which is full of advertisements?
[SCREENSHOT](https://prnt.sc/rxmhwu SCREENSHOT) - mtg5usoj.unaux.com
7 - Whenever I try to install a simple plugin bought or downloaded from my old sites it always gives me error.
[SCREENSHOT](https://prnt.sc/rxmgbf SCREENSHOT)
Warning: set_time_limit () has been disabled for security reasons in
Fatal error: Maximum execution time of 20 seconds exceeded
For now I am testing your service, although I must say that it is not so bad apart from a bit of slowness in uploads, but I would like these problems to be solved also because if in the future I wanted a PREMIUM service here with you, I would not want that every 2 or 3 minutes gives me errors that I don’t want to happen. Thanks in advance for the work you do, Happy Holidays to you too.
Forget everything I wrote … change manager … it’s not worth waiting all this time for easy questions.
