Something wrong with my website?
Hi. I created a website here at ProFreeHost today, and my website isnt working correctly. I’ve uploaded index.php to my htdocs folder, and at my website is only showing: http://webcubed.ezyro.com/legacy
Why dosnt it work?
UPDATE: Now its not redirecting to the index.html file automaticlly when I go to the link webcubed.ezyro.com
Why dosnt it work?
Activation can take sometime after you create new cpanel account. Now your website is loading fine. Are you still experiencing the issue?
Yeah, its not redirrecting to the index.html file automaticlly…
Your website is loading the index.html file exactly as it should. I see TEST when loaded.
Hi again.
When you just go to http://webcubed.ezyro.com you dont come directly to the index.html file, as you are supposed to…
Solved it.. you needed to include www. in front of the domain name.
im having same problem
