[Solved] Configure php ini for max execution time
Hi, is there a way to configure php ini to increase max execution time? I’m using WordPress with a theme that has a demo importer. I can’t properly install it and always failing due to max execution time (I have tried it locally btw and it works as expected)
Thanks.
nvm I got it working by setting it via htaccess file, thanks.
I’m here trying to figure out the same this. I’m tried it all including htaccess. Can you share your file?
I’m trying to increase Max Upload in php ini can help. Is it urgent…
