Hi, in my control panel i can see as quota UNLIMITED… but on the control panel i can see that i have used like 5 gb… and i have non more free space to upload on ftp…
How is possible?
How is possible?
Inodes
INODES are specific to the UNIX file structure and that is what is causing the issues
> @TheCrafters said:
How is possible?Inodes
can you explain?
in the control panel i can see that there is no more free space…
how is possible if the space is unlimited?
> @franke said:
INODES are specific to the UNIX file structure and that is what is causing the issuescan you explain?
https://profreehost.com/support/account-management/everything-you-need-to-know-about-inodes
Have you checked the Knowledge Base?
The storage is unlimited but INODES aren’t, and reaching that limit is probanbly causeng the error.
Can you check the Inodes Usage in the right sidebar of Cpanel?
Inodes Used 4 % (1258 of 30019)
don’t think that is a inodes problem…
Yes you are right about that…
Do you actually see a problem when connecting to FTP? Can you give us a screenshot?
