while updation any file of php extension in my site aravind.ezyro.com/cts i throw a error of this page .please help me to solve the error.
Hi there, welcome to the forum!
That 403 page from openresty comes from the server’s security filter. It blocks requests whose submitted data matches patterns it treats as risky, such as SQL-like text, HTML or script tags, full URLs, or certain special characters in form fields. Since the error appears on rtgs_form_save, the data your form is sending is the most likely trigger.
A few things to check:
Test with simple input. Submit the form using plain text in each field (letters and numbers only). If it saves, add your real values back one field at a time to find which one gets blocked, then adjust or encode that input.
Permissions. Files should be 644 and folders 755. Anything else can also cause a 403.
.htaccess. If you have one in
/ctsor/cts/rtgs, temporarily rename it and test again. -
Editing files. If you get this when saving a PHP file in File Manager, upload it through FTP (FileZilla) instead. File Manager saves go through the same filter.
The security filter can’t be disabled or whitelisted on free hosting, so the request needs to be adjusted to pass it. Debugging the application code itself is outside what we can help with, but let us know what you find from the steps above.
